10% Biospritbeimischung ab 2009 - Auswirkungen?
Gehe zu Seite Zurück  1, 2, 3 ... 7, 8, 9, 10, 11  Weiter
Der EnglaenderOffline
Anmeldungsdatum: 08.07.2004
Beiträge insgesamt: 1096
 →  112.000 km
BeitragVerfasst am : Di, 1. März 2011, 12:40    Titel: Antworten mit Zitat
Unten ein paar Aussagen öffentlicher Stellen bez E10:
Einmal von einer Aussie Gov Seite und Shell UK.
Macht euch ein Bild davon und tankt es nicht!
Beispiele:
Australische Regierungs Webseite:
The Australian Government has limited the amount of ethanol in petrol to 10%. This complies to the Australian Fuels Quality Standard. Ethanol fuel WILL reduce your fuel economy. It contains less energy than normal petrol.
E10 ethanol blend is NOT recommended as there are material compatibility and drivability issues. E10 may be used in emergency situations.
Antwort von Shell Uk was passieren kann:
The residue can manifest itself as either a gum or lacquer-like film or deposit, or a gel-like substance. This residue would be a combination of low-volatility constituents and detergent additives that are found in gasoline, but concentrated after evaporation
Desweiteren:
Unfortunately the simple answer to your questions is that 'There isn't a simple answer'. The Issues you raise are certainly real issues for vintage car owners. The fuel we sell will continue to comply with the relevant fuel standards and specifications as it did previously. The finished petrol will meet the UK gasoline standard EN228, and the maximum amount of ethanol blended into the fuel will be in line with this and the RTFO (renewable fuel transport obligation - 5% max). However that doesn't really help owners of vintage vehicles. There are serveral things you can do to minimise the effects of ethanol. Firstly run a non-alcohol based fuel stabilizer all year round. As you say, older engines were designed primarily for straight gasoline, and using ethanol without protection may cause corrosion of some metals in the engine. It also may damage natural rubber and cork parts. Fuel Stabilizers (I believe Stabil do a product) contain additives to protect against rust and corrosion caused by ethanol fuel blends. If practical Install a water separation filter and fuel filter, and replace fuel lines, gaskets or o-rings with new ethanol resistant materials. Similarly replace the fuel tank if necessary with one made from an ethanol resistant material.
Technical Information Services
Shell U.K. Oil Products Limited
Registered in England and Wales
Registered Number : 3625633
Registered office: Shell Centre, London SE1 7NA
oder hier auf Deusch
http://www.derwesten.de/leben/auto-und-verkehr/Ver ....... f-E10-id4345265.html
des weiteren hier:
http://www.fr-online.de/wirtschaft/energie/verwirr ....... 7405756/-/index.html
Gruss von der Insel
rotschopfleinOffline
Anmeldungsdatum: 30.04.2004
Beiträge insgesamt: 1246
 →  89.000 km
SXC 625, 04er
ADV 1290R, 19ner
 →  45.000 km
BeitragVerfasst am : Di, 1. März 2011, 19:38    Titel: Antworten mit Zitat
Wer E10 tankt braucht morgens nicht mehr in den Spiegel schauen. (weil Obrigkeitshörig) Mad
hotbrowserOffline
Anmeldungsdatum: 31.07.2010
Beiträge insgesamt: 1117
Suzuki SV650
BeitragVerfasst am : Mi, 2. März 2011, 21:21    Titel: Antworten mit Zitat
rotschopflein @ Di, 1. März 2011, 19:38 hat folgendes geschrieben:
elninja13Offline
Anmeldungsdatum: 13.11.2005
Beiträge insgesamt: 1821
KTM LC8 Adv 1290 R
BeitragVerfasst am : Do, 3. März 2011, 7:36    Titel: Antworten mit Zitat
recht interessanter bericht zum thema e10 und "bio".
Report München
Don`t touch a running system!
ArthosOffline
Anmeldungsdatum: 09.11.2007
Beiträge insgesamt: 2394
KTM LC8 950 Adventure S 2003
 →  58.000 km
BeitragVerfasst am : Do, 3. März 2011, 9:35    Titel: Antworten mit Zitat
wollt ihr lieber warten bis das Öl alle ist und dann anfangen mit weinen ?
ekkoOffline
Anmeldungsdatum: 21.02.2008
Beiträge insgesamt: 357
TTR 600, 2001
KTM Mofa
BeitragVerfasst am : Do, 3. März 2011, 9:47    Titel: Antworten mit Zitat
Nee, schneller alternative Antriebskonzepte voranbringen.
Das möchte die Öllobby aber scheinbar nicht.
Ekko
WichtlOffline
Anmeldungsdatum: 23.08.2008
Beiträge insgesamt: 466
KTM LC8 Adv 990 S, 2008
BeitragVerfasst am : Do, 3. März 2011, 10:34    Titel: Antworten mit Zitat
Arthos @ Do, 3. März 2011, 9:35 hat folgendes geschrieben:
Das Öl ist seit 40 jahren in 10 Jahren alle.
ArthosOffline
 →  58.000 km
BeitragVerfasst am : Do, 3. März 2011, 10:42    Titel: Antworten mit Zitat
stimmt, aber es wächst nun mal nicht nach oder zumindest nur seeeehr langsam, irgendwann isses wirklich alle und bis dahin wird die Gewinnung immer schwieriger und teurer.
DesertcarlOffline
Anmeldungsdatum: 07.01.2010
Beiträge insgesamt: 490
BeitragVerfasst am : Do, 3. März 2011, 11:15    Titel: Antworten mit Zitat
Mit dem Glauben an die "abiotische und nicht-fossile Theorie der Entstehung von Erdöl" fährt sich Kati noch entspannter Rolling Eyes
http://www.eike-klima-energie.eu/news-anzeige/oel- ....... n-erdoel-und-erdgas/
el ce achtlerOffline
Anmeldungsdatum: 23.09.2006
Beiträge insgesamt: 828
 →  114.000 km
BeitragVerfasst am : Do, 3. März 2011, 12:26    Titel: Antworten mit Zitat
google dieses EIKE institut doch mal. Ohne nun auf den Wahrheitsgehalt auf der EIKE page oder der weiteren Quellen eingehen zu wollen, erfährst Du, daß dieses Institut privatfinanzierte Tochter eines ähnlichen Instituts in den USA ist, daß von EXXON offenbar großzügig mit Spenden bedacht wird. dry
Diese Öl-Thesen will ich mal von nem unabhängigen Wissenschaftler hören... mellow
Unabhbängig davon halte ich das mit dem E10 für Geldmacherei und ausgemachten Humbug. Grundsätzlich nette Idee, aber die Ökobilanz inkl. Flächenrodung und Mehrverbrauch soll mir mal einer vorlegen.
... mach, daß es geht! ....
below90Offline
Anmeldungsdatum: 15.09.2008
Beiträge insgesamt: 69
IFA KR 51/2 "Schwalbe" , 1981
BeitragVerfasst am : Do, 3. März 2011, 12:43    Titel: Antworten mit Zitat
ich komme aus der Motorenecke und ich kann nur sagen:
Erst mal Finger weg von dem Zeugs ! Mad
Die Öle in den Motoren sind in den Zeiten von Direkteinspritzern, Abgasrückführungen,...... sehr stark belastet (z.B. Hoher Benzineintrag ins Öl, etc.). Auf anderen Kontinenten ist das nicht so das Thema, denn dort laufen in der Regel nicht die High-End-Versionen.
Die Auswirkungen durch die zusätzliche Nutzung von Bio-Sprit wird derzeit heftig diskutiert und kritisch bewertet.
....... beste Grüße von below ...... Mad
Beiträge insgesamt: 2276
Harley Davidson XR 1200, 2009
BeitragVerfasst am : Do, 3. März 2011, 16:55    Titel: Antworten mit Zitat
Und schon hat sich das Thema (vorerst) erledigt:
http://www.spiegel.de/wirtschaft/unternehmen/0,1518,748899,00.html
 →  112.000 km
BeitragVerfasst am : Do, 3. März 2011, 18:22    Titel: Antworten mit Zitat
Dieser Artikel geht in die richtige Richtung aber der letzte Absatz sagt alles!
"Mit einem eindringlichen Appell an die Autofahrer hatte die Mineralölwirtschaft am Mittwoch zum Umstieg auf den neuen Bio-Supersprit E10 aufgerufen. Picard rief die Autofahrer auf, das neue Super-Benzin E10 mit einer Beimischung von zehn Prozent Ethanol zu tanken"
Alkohol zieht Wasser das laesst sich nicht wegdiskutieren, schmiert nicht, haertet Dichtungen aus etc.
Aus einem anderen Forum:
" Wasser ist schwerer als Benzin und sinkt im Tank mit dem Alkohol nach unten. Dort kann es zu einer Phasentrennung (oder Entmischung von Benzin und Wasser) kommen wobei unten dann eine Wasserlache im Tank steht und da nun einmal bei den meisten Tanks der Auslauf unten ist (bei unserem Bike natürlich auch!) kann der Motor anstelle von Benzin einen kräftigen Schluck Wasser bekommen!!!
Dies trifft besonders dann zu, wenn das Motorrad/Auto lange steht, denn dann kommt es eher zu einer Phasentrennung als wenn das Benzin bewegt wird (während der Fahrt). "
Wieder alles nur ein Machwerk um uns das Geld aus der Tasche zu ziehen damit die Energie Konzerne ihre Profite weiter nach oben zu schrauben.
Irgendwann stellt sich dann die Frage; Essen oder Benzin aufgrund der benoetigten Anbauflaeche fuer diesen Schwachsinn.
Ein weiteren Artikel vom 26.3.2010 aus Sience Daily:
Dr Oliver Inderwildi, Head of the Low Carbon Mobility centre at the Smith School, said: 'The common belief that alternative fuels such as biofuels could mitigate oil supply shortages and eventually replace fossil fuels is pie in the sky. There is not sufficient land to cater for both food and fuel demand. Instead of relying on those silver bullet solutions, we have to make better use of the remaining resources by improving energy efficiency. Alternatives such as a hydrogen economy and electric transportation are not mature and will only play a major role in the medium to long term.'
Auf Deutsch der Bio Sprit ist Pustekuchen und die Welt hat nicht genug Land fuer Essen und Benzin!
Wenn es interessiert und wie es dazu kam
http://www.mandadeals.co.uk/sector-watch/310881/sowing-the-seed.thtml
Dieser sogenannte Biosprit kommt aus folgenden Laendern fuer den Europaischen Markt; Sierra Leone, Angola, Mozambique, Kenya
die haben so viel zu Essen da-unten das sie aus Gesundheitsgruenden garnix mehr Essen und lieber Sprit fuer uns anbauen iat doch nett, oder?
Gruss von der Insel
DesertcarlOffline
BeitragVerfasst am : Do, 3. März 2011, 21:54    Titel: Antworten mit Zitat
@el ce achtler
Ölmulties wie EXXON haben kaum Interesse an alternativen Theorien. Die leben ja davon, mit der drohenden Verknappung und zunehmend schwierigen Gewinnung von Rohöl noch mehr Gewinne drauf zu schlagen. Seriöse Verfechter der abiotischen Erdöltheorie haben genauso Gegenwind wie Klimawandelgegner.
Abba, dat kann uns ja wurscht sein, Hauptsache das E10 kommt weg
henningdierksOffline
Anmeldungsdatum: 09.04.2007
Beiträge insgesamt: 279
BeitragVerfasst am : Do, 3. März 2011, 22:47    Titel: Antworten mit Zitat
Hallo was ist denn da los Question
Der Bürgerkäfig ist natürlich in Taximanier mit 6,5 l Öl unterwegs, die @ ist bei uns an der kalten Ostsee noch am schlummern.
Frage an die Techniker:
was soll ich denn nun nehmen Question Question Question , wenn ich endlich der Guten wieder freien Lauf lassen kann Question Question Question
VG Henning
Seite 8 von 11
[ Time: 0.1476s ][ Queries: 37 (0.0955s) ]
