Clutch Dragging
claferalOffline
Anmeldungsdatum: 26.08.2003
Beiträge insgesamt: 21
BeitragVerfasst am : So, 9. Apr 2006, 1:15    Titel: Clutch Dragging Antworten mit Zitat
Hello,
I write from Spain. I have a problem of clutch dragging in my 04 LC8 since it had 15000 km. Now it has 34000 km. I have reported this problem to my KTM Dealer. They changed the clutch disk (I paid for it) and the push rod, hidrulic oil but the problem hasn´t been solved yet. KTM Spain doesn´t give me a solution.
I use Motorex 10W50 and hidraulic mineral oil as hidraulic oil for the clutch.
Do you what it is the problem? What can I try to solve it?
Thanks
BeitragVerfasst am : So, 9. Apr 2006, 4:27    Titel: Antworten mit Zitat
First of all, there is a problem, and KTM knows that.
You should not pay for any thing, during the warranty.
Many reasens, are possible.
Can you describe the "Clutch Dragging" more detailed.
Can you read in German?
Then I will search some threads for you.
claferalOffline
BeitragVerfasst am : So, 9. Apr 2006, 18:13    Titel: Antworten mit Zitat
Spain is different!! The Spanish KTM Importer doesn´t give a good service. So they don´t pay nothing about disk, clutch cylinder, and other things. For example last year I have to pay for a radiator cap, a new slave cylinder piston, a rear brake repair kit and clutch disk. The bike is great but the Customer Service is the worst I have seen.
Whe I say that the clutch drags, it means that the clutch doesn´t disengaged completely. So when you shift a gear the gear box makes a big "crank". And when you shift a lower gear the engine brakes before you pull the clutch lever. When the engine is hot the problem is worse. My mechanic says that the clutch don´t open all the way. So he put a shim at the end of the push rod and the problem was solve when the engine was cold. But when it is hot the problem appears again.
I can´t read German. It will be very nice from you if you answer me in English
Best Regards
SteveOffline
Anmeldungsdatum: 19.05.2003
Beiträge insgesamt: 203
EXC-R 450, 2008
GasGas 200
BeitragVerfasst am : So, 9. Apr 2006, 19:14    Titel: Antworten mit Zitat
i had more or less the same problems at about 20.000km.
At the end the problem was solved with new clutch springs. Now the clutch workes again perfect.
Grüsse
Stephan
BeitragVerfasst am : So, 9. Apr 2006, 20:13    Titel: Antworten mit Zitat
It sounds very ugly, you need help
You have PM
PS: One of my target is “la carino”, next goal will be the black see, 14 day’s ago ;-}}
fr.jazbecOffline
Anmeldungsdatum: 11.04.2006
Beiträge insgesamt: 1670
BMW 318i Cabrio Bj.92
BMW Z3 Coupe 2,8
 →  165.000 km
BeitragVerfasst am : So, 16. Apr 2006, 11:15    Titel: Antworten mit Zitat
try to change the motoroil.use shell advance ultra 15w-50.in the german newspaper "enduro" they had problems with the clutch using motorex.after changing the oil the clutch works good
blitzOffline
Anmeldungsdatum: 23.02.2003
Beiträge insgesamt: 1114
 →  82.000 km
KTM LC 4 Adventure Bj.04
BeitragVerfasst am : Mo, 17. Apr 2006, 12:49    Titel: Antworten mit Zitat
buenos dias claferal,
i think you should report your problems direct to ktm austria.
if the/your spanish dealer do not show the correct reaction on your problems. you (we) do have a europe wide garranty - and your dealer have to react in a warranty form. so write your problems up to now and the bills to ktm austria direct.
with best regards
blitz
claferalOffline
BeitragVerfasst am : Mo, 17. Apr 2006, 23:23    Titel: Antworten mit Zitat
Do you where I can send my reclamation? Post Sales Department? Quality Department?
Thanks to everybody for your answers
blitzOffline
 →  82.000 km
BeitragVerfasst am : Mi, 19. Apr 2006, 7:53    Titel: Antworten mit Zitat
send it to both adresses, so that someone who cares did get it!!
best regards
blitz
alpenfreundOffline
Anmeldungsdatum: 17.02.2005
Beiträge insgesamt: 2413
KTM LC8 1190 Adventure, 2014
BeitragVerfasst am : Mi, 19. Apr 2006, 11:22    Titel: Antworten mit Zitat
blitz @ Mi, 19. Apr 2006, 8:53 hat folgendes geschrieben:
best regards
blitz
Hallo! This is the person for Austria, should help you too:
Manfred Faugel
KTM Sportmotorcycle AG
Abt. Kundendienst
V2 macht high!
Grüße Jörg
[ Time: 0.0890s ][ Queries: 27 (0.0652s) ]
