Octane Selector
ReneVDBOffline
Anmeldungsdatum: 02.03.2003
Beiträge insgesamt: 64
BeitragVerfasst am : So, 22. Jun 2003, 19:56    Titel: Antworten mit Zitat
Hi All,
In my quest to optimize the LC8, I have tried out the following thing: I 'unplugged' blink the Octane selector cable, to select the ignition program for low octane fuel (below 95), although the fuel I'm using is high octane (9Cool.
For now I only performed a 2-minute test-drive, and the bike performs a lot smooter from 2000 to 6000 RPM. sleep
I suppose (hope) that the ignition program will be retarded a bit to avoid pre-combustion of the fuel mixture.
I also read that the output is going to be lower: less than 98 HP (85 perhaps?) unsure
Are there any people that have enough technical background to explain what changes? huh
ohmy Is there any reason why this should not be done ?
I will try out to use the bike in various situations the coming week. I will try to keep you posted with my practical findings.
Ciao, René
Brussels - Belgium
ReneVDBOffline
BeitragVerfasst am : Mo, 23. Jun 2003, 19:02    Titel: Antworten mit Zitat
ReneVDB hat folgendes geschrieben:
Hi All,
For now I only performed a 2-minute test-drive, and the bike performs a lot smooter from 2000 to 6000 RPM.  sleep ...
Hi again,
So my limited test shows the following:
* not that much less power, the bike can get upto high revs. Rolling Eyes
* not much smooter except that the bike does not 'knock' that much. Sad
* the 'GAP' between 3000 and 4000 is the same or worse than before Mad
I will have to revert to the normal position again. Sad
P.S. What I reported earlier about higher fuel consumption is NOT true: the left gas tank leveler was still closed...
Acutally, this consumption is not high at all: 11 liters on 160 KM is about 6.8 KM/100
[ Time: 0.0697s ][ Queries: 23 (0.0326s) ]
