caballero LC8 Junkie Anmeldungsdatum: 12.12.2002 Beiträge insgesamt: 305
Verfasst am : Mo, 23. Jun 2003, 13:53 Titel: |
in italy is impossible to have KAROO 2.... at this moment not producted....
but also SKORPION A/T!!!!!!
in august i go to nordkapp and i have to change tires!!!!
how is the situation in germany/austria/swizerland????? _________________ <span style='color:orange'>Ciao Matteo - KTM 950 ADV S n.1298 "caballeroarancio"- Sondrio - Italia
www.lc8.org
www.quellidellelica.com
www.advrider.com
nick:barbasma</span>
Zuletzt bearbeitet von caballero am Mo, 23. Jun 2003, 13:54, insgesamt einmal bearbeitet |
Stollenritter Tremalzobezwinger
Anmeldungsdatum: 12.12.2002 Beiträge insgesamt: 204 Alter: 59
Verfasst am : Mo, 23. Jun 2003, 14:14 Titel: |
AT www.butzner-motorradreifen.de you may buy:
150/70 R 18 M/C 70H MCE Karoo
Bestellnummer: 1268800
Unser Preis: 103,00 EUR
90/90-21 M/C 54R MCE Karoo 2 Front M+S
Bestellnummer: 1203100
Unser Preis: 49,50 EUR
The tires are on stock, I just phoned them and asked for you.
Problem: They do not like to deliver to Italy, but try to contact them... there is always a way!
Greetings
DIRK
Verfasst am : Mo, 23. Jun 2003, 15:25 Titel: |
thank's a lot...
but....
there's no SCORPION that LC8 mount... is a special tire with code "V"... (240 kmh max)...
this shop have the model with "H" code... _________________ <span style='color:orange'>Ciao Matteo - KTM 950 ADV S n.1298 "caballeroarancio"- Sondrio - Italia
www.lc8.org
www.advrider.com
Zuletzt bearbeitet von caballero am Mo, 23. Jun 2003, 15:46, insgesamt einmal bearbeitet |
Verfasst am : Mo, 23. Jun 2003, 16:01 Titel: |
Hi Matteo
Between Delebio and Morbeno is a Distributore per Gomme (Idustrial Zone, green Building).
He has most time some standart tyres for motorbikes on stock, ask him.
Very good service and fine equipment
Regard's Peter
_________________ Peter |
Klapphelmfahrer Schlammspringer
Anmeldungsdatum: 12.05.2003 Beiträge insgesamt: 164
Verfasst am : Mo, 23. Jun 2003, 16:07 Titel: |
Ciao Matteo,
io prendo le gomme da moto sempre da Holert Konz a Rosenheim o a Monaco in Germania. Se telefoni qualche giorno prima, ti procurano tutte le gomme a un prezzo molto inferiore che in Italia. Se vai al Capo Nord puoi passare lì direttamente all'inizio del tuo viaggio.
Gli indirizzi:
Holert Konz Meglingerstraße 15
81477 München
Tel (0 89) 78 29 12
Fax (0 89) 78 67 85
Kufsteiner Straße 69
83026 Rosenheim
Tel (0 80 31) 3 56 26-3
Fax (0 80 31) 3 56 26-40
Sul sito trovi anche altri indirizzi in Germania:
www.holertkonz.de
Ciao Berni _________________ Obn bin i, des isch koa Zweifel, wia i wieder oikimm des woaß der Teifl....
Zuletzt bearbeitet von Klapphelmfahrer am Mo, 23. Jun 2003, 16:15, insgesamt einmal bearbeitet |
Verfasst am : Mo, 23. Jun 2003, 16:22 Titel: |
@bruggma
vielen danke!!!
@klapphelmfahrer
grazie mille...
il problema è che siamo di fretta... solo due settimane...dubito che riusciremo a fermarci per un cambio gomme...
ho fatto una ricerca su internet... non esistono le gomme 150/18 a codice V con indice di carico 70....
un mio caro amico fa il gommista e dice che il distributore per il nord italia non ha notizie delle gomme per l'LC8... non le hanno ancora prodotte come ricambio.. solo come primo equipaggiamento...
mi ha detto che capita sempre quando fanno pneumatici specifici.... anche per la BMW X5 i clienti hanno aspettato mesi per avere le gomme!!!
spero di avere notizie entro fine luglio...
lo stesso problema c'è per avere le camere d'aria da 150/18... devo portarle come ricambi... _________________ <span style='color:orange'>Ciao Matteo - KTM 950 ADV S n.1298 "caballeroarancio"- Sondrio - Italia
www.lc8.org
www.advrider.com
nick:barbasma</span> |
Verfasst am : Mo, 23. Jun 2003, 16:39 Titel: |
Puoi provare a contattare KTM Sommer, se ti possono procurare e spedire le gomme con un corriere.
Naturalmente è una soluzione un pò costosa.
Buona fortuna
Berni _________________ Obn bin i, des isch koa Zweifel, wia i wieder oikimm des woaß der Teifl.... |
Guest
Verfasst am : Mo, 23. Jun 2003, 18:04 Titel: |
| Klapphelmfahrer hat folgendes geschrieben: | Puoi provare a contattare KTM Sommer, se ti possono procurare e spedire le gomme con un corriere.
Buona fortuna
Berni |
der Reifenversand in das Ausland ist seit Anfang Juni extrem teuer geworden und praktisch nicht zu empfehlen. Wenn der 950er Fahrer von Italien zum Nordkap fährt, kommt er "praktisch " bei uns vorbei. Dann kann z.B. so ein Reifensatz ambulant gewechselt werden.......
Wir haben viele 640er Adventurekunden, welche per Achse aus Skandinavien kommen, in Oberhausen Umbauten vornehmen lassen, danach nach Köln fahren und dann weiter per Autoreisezug nach Port Bou/Narbonne.....
mit sportlichen Grüßen SOMMER KTM Rainer Kroll |
Verfasst am : Mo, 23. Jun 2003, 18:25 Titel: |
| Guest hat folgendes geschrieben: | | Klapphelmfahrer hat folgendes geschrieben: | Puoi provare a contattare KTM Sommer, se ti possono procurare e spedire le gomme con un corriere.
Buona fortuna
Berni |
@SOMMER KTM
vielen dank....
so the tires exist in germany!!!
so why not in italy????? _________________ <span style='color:orange'>Ciao Matteo - KTM 950 ADV S n.1298 "caballeroarancio"- Sondrio - Italia
www.lc8.org
www.advrider.com
Verfasst am : Mo, 23. Jun 2003, 19:35 Titel: |
Hi Matteo
Why did you dont check the dealer list for dealers in Engadina ore Ticino.
If you cant find someone, all tyres in switzera are distributet over
Hostettler AG
Haldenmattstrasse 3
CH-6210 Sursee
Tel.: 041/ 926 61 11
Fax.: 041/ 926 62 93
Internet:
www.hostettler.com www.yamaha.ch
info.hostettler.com
Verfasst am : Mo, 23. Jun 2003, 21:33 Titel: |
| Bruggma hat folgendes geschrieben: | Hi Matteo
Hostettler AG
Haldenmattstrasse 3
CH-6210 Sursee
Internet:
info.hostettler.com
Peter |
@bruggma
vielen..vielen..vielen dank!!!! _________________ <span style='color:orange'>Ciao Matteo - KTM 950 ADV S n.1298 "caballeroarancio"- Sondrio - Italia
www.lc8.org
www.advrider.com
maddan Fahrschüler Anmeldungsdatum: 07.01.2003 Beiträge insgesamt: 11
Verfasst am : Fr, 27. Jun 2003, 11:24 Titel: |
hoschi kann ich nicht empfehlen. teurer als bei hostettler in sursee wird man nirgends einen reifen kaufen er hat den GENERALIMPORT, d.h. das metzeler monopol für die CH. jeder eigenimporteur (selbsständiger reifenhändler) wird von hoschi knallhart sanktioniert und mit nichts mehr beliefert.
hole meine marathon immer in DE. kosten 50% weniger als in der ch. z.b. bei www.reifenversand.com |
Verfasst am : Fr, 27. Jun 2003, 11:34 Titel: |
i've found the tires in TICINO (CH)... but i'm waiting in italy beacause in CH are more expensive... _________________ <span style='color:orange'>Ciao Matteo - KTM 950 ADV S n.1298 "caballeroarancio"- Sondrio - Italia
www.lc8.org
www.advrider.com
Verfasst am : Fr, 27. Jun 2003, 12:06 Titel: |
@caballero
Dont buy tyres by a offical bike dealer, tyre discounter in Switzera interna are much cheeper,
cheeper then Distributor di Gomme in Italy.
Hallo Maddan
Ich habe mir gerade einen Satz Michelin Anakee gekauft.
50% auf Listenpreis, Räder demontieren, montieren SFr. 10.- € 7.50
Das ist derselbe Rabatt den ich auch auf die Metzeler Tourance bekommen hätte.
Woher die Dinger kommen, ist mir ehrlich gesagt gleich.
Verfasst am : Fr, 27. Jun 2003, 12:40 Titel: |
| Bruggma hat folgendes geschrieben: | @caballero
Hallo Maddan
Peter |
danke... _________________ <span style='color:orange'>Ciao Matteo - KTM 950 ADV S n.1298 "caballeroarancio"- Sondrio - Italia
www.lc8.org
www.advrider.com
