Gaspump gasket (Benzinpumpe Dichtung)
SzepyOffline
Anmeldungsdatum: 22.07.2003
Beiträge insgesamt: 30
BeitragVerfasst am : Di, 20. Apr 2004, 15:04    Titel: Antworten mit Zitat
Hi!
Has anybody's gaspump stopped? The first case was in November, on route to the local KTM dealer's cross testday. After 20-30 kms on dirtroads with some large (more than 5-8m long) muddy pools, the bike stopped. Fortunately we could tow it to the nearest asphalt road and the dealer's van took it to the service. We had no idea what happened, until they inspected the pump and found mud under the plastic cup.
Cleaned it, ordered a new one and gave me the old one back until the new arrives.
It happened a few weeks later, and the new operated well until the the first "serious" offroad trip, first weekend of April.
4 days later, the bike stopped. I could hardly push it to the next gas station... I started with the gaspump, and bingo, mud inside the switch of the pump... Cleaned it (used WD40 and high pressure air). After a while it started to work, but only with the plastic cap off the pump. Next morning went to the service. They gave my old but workin' pump back, and ordered another one. It worked perfectly on the whole weekend, on a tour in Slovakia with minimal offroad (only 40-50kms of gravel), but it stopped again last Saturday. You won't guess, it was full of mud. Hot mud...
I cleaned it again (started to get the "KTM Official Gaspump Cleaner" degree), but it did not help. The pump only worked when it was turned on (ignition or safety switch), one stroke, but not more. And it get very hot, could hardly touch (60-70 Celcius).
Any similar experiences? Ideas to seal the pump well?
Szepy
 →  159.000 km
BeitragVerfasst am : Di, 20. Apr 2004, 15:51    Titel: Antworten mit Zitat
Szepy hat folgendes geschrieben:
Fortunately not :)
But thanks for this hint...
Take a bicycle tube, some silicone and wire... Wink
BeitragVerfasst am : Di, 20. Apr 2004, 19:03    Titel: Antworten mit Zitat
@Schradt
Silikon etc. ist FALSCH!
Die Pumpe hat einen Auslauf für Kondenswasser. Der sollte in ledem Fall funktionieren. Die Kunststoffkappe könnte man natürlich gegen die Pumpe mit gutem Klebeband abdichten. Das habe ich aber schon mal geschrieben wegen meinen Erfahrungen mit der identen ATwin-Pumpe Wink wacko .
 →  159.000 km
BeitragVerfasst am : Di, 20. Apr 2004, 19:44    Titel: Antworten mit Zitat
Wo nix rein läuft, braucht auch nichts raus laufen.
Oder zieht die das Wasser aus dem Benzin? huh
Also ich wüsste nicht was gegen eine 100%ige Abdichtung sprechen würde, wenn die Pumpe echt so wasserscheu ist, wie Szepy schreibt. Also teures, extra klebriges und hitzebeständiges Silikon verwenden.
Meine muss aus ner anderen Charge sein, denn die ist dutzende Male tauchen gegangen und monatelang im Dreck gelaufen...
Das Gehäuse ist verrostet, eine Plastikkappe habe ich bisher nie abgenommen.
Guest
BeitragVerfasst am : Di, 20. Apr 2004, 19:49    Titel: Antworten mit Zitat
They're not bad, but you have to to care! Only non acidic materials can be used or the corrosion eats the switch.
I realized, that such amount of mud and water cannot get under the cap through the less than 1mm size hole - I'll try to seal the cap-pump surface and the wires' hole.
Can you advise me good sealing tape? The wire hole'll be made with silicon gel.
The
Sorry I did not read that. "Good" to know that a japanese part makes such a good bike unmobile... Sad
Szepy
Guest
BeitragVerfasst am : Di, 20. Apr 2004, 19:53    Titel: Antworten mit Zitat
That was lost:
The condensed water opening with the long tube will remain open of course - I realized it's made for good reason - just did not know about the condensed water...
Szepy
 →  159.000 km
BeitragVerfasst am : Di, 20. Apr 2004, 20:15    Titel: Antworten mit Zitat
Achja, da geht ja noch ein offener Schlauch ab... Dann macht das komplette Abdichten wohl nicht viel Sinn.
Dann würde ich die Elektrik mit Polfett einsprühen und den Rest den Original-Dichtungen überlassen.
Werde mir das aber mal genauer ansehen...
SzepyOffline
BeitragVerfasst am : Di, 20. Apr 2004, 20:31    Titel: Antworten mit Zitat
The tube goes high enough and is thin enough not to get so much water and mud that could cause such problems...
I understand it's not an U-Boot, but I thought the largest maker of the offroad bikes ("Sportmotorcycles") looks finds the proper solutions for an avarage use - nothing extreme.
Szepy
BeitragVerfasst am : Di, 20. Apr 2004, 20:32    Titel: Antworten mit Zitat
Warum glaubt mir der Schradt nicht? wacko Wink
Das ist meine alte AT Pumpe. Die defekten Innereien habe ich entfernt.
Die 2 Metallstutzen sind Benzinzu/ablauf, am Plastedeckel ist ein Schaluchstutzen für Kondenswasser, gegenüber gehen die Stromstrippen rein und oben sollte eine kl. Schraube den Decken festhalten.
 Dateigröße:  63.54 KB
 Angeschaut:  20438 mal
Zuletzt bearbeitet von Benzinschnüffler am Di, 20. Apr 2004, 20:35, insgesamt einmal bearbeitet
BeitragVerfasst am : Di, 20. Apr 2004, 20:35    Titel: Antworten mit Zitat
und im zerlegten Zustand. Zu sehen ist der O-Ring der alles abdichten sollte aber das nicht richtig tut. Die Gummihülle ist nur zur spannungs- und vibrationsfreien Montage gedacht.
 Dateigröße:  68.02 KB
Zuletzt bearbeitet von Benzinschnüffler am Di, 20. Apr 2004, 20:36, insgesamt einmal bearbeitet
SzepyOffline
BeitragVerfasst am : Di, 20. Apr 2004, 20:39    Titel: Antworten mit Zitat
That's it!
Man, we can believe him, that's the same as the LC8's pump! :)
So, what was the proper duct-tape for the cup?
Szepy
Guest_Nobody
BeitragVerfasst am : Di, 1. Jun 2004, 22:37    Titel: Antworten mit Zitat
Hallo Schnüffler!
Schade daß Du die Kontakte nimmer drauf hast um zu zeigen wie diese nach 50tkm aussehen.
Ich hab mal ein Bildchen von noch gut erhaltenen Kontakten gemacht.
Ups,..hab grade in der Hilfe erfahren daß ich keine Bilder hochladen darf als Fahrschüler. Dazu fehlt mir der "Browse" Button.
Naja,..dann eben ned.
LG, Nobody
funracerOffline
Anmeldungsdatum: 13.11.2002
Beiträge insgesamt: 3219
BeitragVerfasst am : Di, 1. Jun 2004, 22:43    Titel: Antworten mit Zitat
Guest_Nobody hat folgendes geschrieben:
LG, Nobody
Du musst eingeloggt sein dazu ( hast als Gast geschrieben...)
Grüßle funny
Guest_Nobody
BeitragVerfasst am : Di, 1. Jun 2004, 22:53    Titel: Antworten mit Zitat
funracer hat folgendes geschrieben:
LG, Nobody
Hallo Funny!
Ich bin eingeloggt,..keine Ahnung warum´s nicht geht!?
Nach dem einloggen bekomme ich ja die Message daß ich eingeloggt bin.
Spielt mir da vielleicht der Gates wieder nen Streich???
LG, Nobody
funracerOffline
BeitragVerfasst am : Di, 1. Jun 2004, 23:44    Titel: Antworten mit Zitat
Hmmm, versteh ich auch nicht wieso Du dann als unregistrierter Gast aufgeführt wirst. Habs auch nie ausprobiert Rolling Eyes Jedenfalls ist dem im Mom so und darum kanst auch keine Bilder reinstellen.
Hast Du Dich richtig mit Name und PASSWORT angemeldet? Versuchs doch nochmal neu...
Grüßle funny
Seite 1 von 4
[ Time: 0.5217s ][ Queries: 44 (0.4011s) ]
