Zwendel Fahrschüler
Anmeldungsdatum: 08.07.2003 Beiträge insgesamt: 7
Verfasst am : Mi, 30. Jul 2003, 23:55 Titel: |
Today , i started to install my tripmaster switch on my KTM 950 S ( last week i placed an order by my KTM dealer item number 582.14.069.044 ) but came to the conclusion that it doesn't fit like it's ment to fit .
So here's a solution to fit it correctly .
Zwendel
Zwendel Fahrschüler
Verfasst am : Do, 31. Jul 2003, 0:04 Titel: |
So , you can see that the pics on this KTM manualpaper are not from a KTM 950 but from a 640 adventure. On leftside of a 950 there are not 2 screws at the mirror standard. So thereby it's not possible to install the tripmaster correctly
( it's impossible to use your turnsignals at this position).
106.19 KB |
5925 mal |
Zwendel Fahrschüler
Verfasst am : Do, 31. Jul 2003, 0:14 Titel: |
You to saw a bit from the retaining bracket ( you will only need the piece for covering the back of the tripmaster), take a longer screw (about 4 cm) then redrill the hole in the center of the tripmaster and the bracket.
Zwendel
29.64 KB |
5924 mal |
gschimmy Hinterradspezi
Verfasst am : Do, 31. Jul 2003, 7:11 Titel: |
Hello Zwendel !
Here`s is a picture how my dealer istalled the Tripmaster switch on the LC 8.
Ist a bit tricky to bring the turn switch in the right position, but it work.
As far as I see at your mounting point this is not the problem, but it must be hard to reach with the thumb.
Greetings
Georg
51.05 KB |
5924 mal |
Guest_Daan
Verfasst am : Do, 31. Jul 2003, 8:20 Titel: |
| gschimmy hat folgendes geschrieben: | Hello Zwendel !
As far as I see at your mounting point this is not the problem, but it must be har to reach with the thumb.
Greetings
Georg |
Hallo!
Vorher hatte ich an meine 620 adv die bedienung an die innenseite von handschutz montiert!
Genau oben die kuppelhebel,wo die finger immer sind!
Mit eine kleine bugel, in 90 graden gebogen, und angeschraubt mit 5 mm bolzen!
War ganz einfagg, sieht gut aus und arbeitet gut!
Leider keine bilder davon!
Groeten van Daan!
Verfasst am : Do, 16. Okt 2003, 9:15 Titel: |
Moin!
Neue Erfahrung zum Thema Tripmasterschalter......
Schon mal probiert den Blinkerschalter mit dicken Winterhandschuhen nach links zu bewegen ?
Nahezu unmöglich, wenn der Tripmasterschalter nach KTM installiert ist. ( siehe Bild weiter oben ) <_<
Werde wohl doch über eine Umsetzung des Schalters nachdenken.
Gruß Schimmi
