Waterloss
SzepyOffline
Anmeldungsdatum: 22.07.2003
Beiträge insgesamt: 30
BeitragVerfasst am : Fr, 1. Aug 2003, 12:28    Titel: Antworten mit Zitat
Hi Olly!
I'll write the new experiences ASAP. The KTM factory had some ideas and sent the proper pieces. Hope they'll help. As I heard they're mainly sealings and O-Rings.
The dealer told me they'll be here on Monday - but it depends on the customs very much Sad.
Here is an avarage tale, that the parts arrive from almost everywhere in days and the custom office sits on them for a few weeks Sad.
It was almost perfekt Smile.
The 10 point solution is "köszönöm". But that's the verb, the noun is: "Köszönet".
That was the "Learn Hungarian easy and fast" lesson for today. Very Happy
Guest
BeitragVerfasst am : Fr, 1. Aug 2003, 12:37    Titel: Antworten mit Zitat
@szepy
i had exactly the same problem as you. next week my dealer will change the head gasket after
communicating with Mattighofen.
regards
harry
BeitragVerfasst am : Fr, 1. Aug 2003, 12:55    Titel: Antworten mit Zitat
@harry
which head gasket ? The cylinder head gasket ?
XT-OllyOffline
Anmeldungsdatum: 17.05.2003
Beiträge insgesamt: 539
BeitragVerfasst am : Fr, 1. Aug 2003, 13:31    Titel: Antworten mit Zitat
@Szepy
Rainer Kroll keeps his nose to the grindstone as long as it takes to solve the problem. That's how I know him - he outed himself as a "Workaholic" Wink He will never leave customers alone with problems. I like that very much... wub
Köszönet for the corrections ! Always good to learn something more. Unfortunately long ago, since I've been in Hungary the last time.
Good luck with your problem,
Olly
Carlo
BeitragVerfasst am : So, 3. Aug 2003, 10:54    Titel: Antworten mit Zitat
The obvious overpressure in the cooling-circuit can only have one reason: a defective cylinder-head-gasket.
Greetings
Carlo
BeitragVerfasst am : So, 3. Aug 2003, 19:22    Titel: Antworten mit Zitat
@Carlo
Peters problem is 100 % turn to the other side.
He has a vacuum in his cooling system.
So, if the gasket is not ok, his bike must have water in the cylinder.......or am I wrong ?
Greetings Schimmi
Giggi
BeitragVerfasst am : So, 3. Aug 2003, 19:50    Titel: Antworten mit Zitat
Hatte heute bei meiner S erstmalig das gleiche Problem... nach der Autobahn plötzlich ein 16tel wasser aus dem überdruck schlauch des kühlers...
morgen kommt sie gleich zum faber und der solls wieder gut machen!
liebe grüsse
giggi
SzepyOffline
BeitragVerfasst am : Mo, 4. Aug 2003, 9:42    Titel: Antworten mit Zitat
@Carlo
Greetings Schimmi
Hi!
Not exactly, I have vacuum only when it cools down. But I hope we'll receive the parts today and will end this problem on this week. The cylinder head gasket is a real option too, but it has to have a very minor problem - since neither the oil, nor the water has any contaminations, that could be seen by eyes.
Time will tell...
Szepy
ktm-pilotOffline
Anmeldungsdatum: 31.03.2003
Beiträge insgesamt: 2182
1. KTM LC8 Adv 1000, 03/05
2. 1190 ADVENTURE R
BeitragVerfasst am : Mi, 6. Aug 2003, 13:51    Titel: Antworten mit Zitat
@Szepy
hello, i think i have the same problem with the cooling system as you. I´m very intrestet what parts will be changed to solve the problem.
Perhaps you can post the KTM-parts list, which will solve the problem.
What will make you virtually certain that the cylinder head gasket is okay. Mabye only the gas flows into the cooling system and not in the other direction?
Greetings and looking forward to your reply
ktm-pilot
ktm-pilot
ADV1000 -->89,1KW
SzepyOffline
BeitragVerfasst am : Mi, 6. Aug 2003, 14:00    Titel: Antworten mit Zitat
@ktm-pilot
In the most of the cases, when the cylinder head gasket leaks oil gets into the water and/or water gets into the oil. The oil becames dull and has foam on it. The water also heats up - because of the hot gases.
Neither of this symptoms appear.
It's also possible that the problem is in the first cylinder head and the water temperature sensor is on the back.
Next week on wednesday we'll take it apart and see what's inside.
Szepy
ktm-pilotOffline
2. 1190 ADVENTURE R
BeitragVerfasst am : Mi, 6. Aug 2003, 14:35    Titel: Antworten mit Zitat
@Szepy
mabye there is also an other case, when the head gasket is minimal defective between the "water" and the "combustion space" fuel gas will flow into the water and press it out of the radiator into compensating reservoir.
The KTM-ideas don´t crack the problem?
when you take it apart on (auseinandernehmen?) wednesday, we will hope the problem will be solved.
pherhaps we will have a progress in the trouble shooting. mabye i can look with an hc-tester whether there are fuel gases in the cooling-water or not before next wednesday.
CU HS
ktm-pilot
ADV1000 -->89,1KW
SzepyOffline
BeitragVerfasst am : Do, 7. Aug 2003, 11:48    Titel: Antworten mit Zitat
@ktm-pilot
That's exactly what I thought...
I'll be next to the bike when it's "cured", hopefully I can even take part at the work so I hope I can write all the expreriences from "the very first hand" Smile .
Szepy
ktm-pilotOffline
2. 1190 ADVENTURE R
BeitragVerfasst am : Mo, 11. Aug 2003, 17:53    Titel: Antworten mit Zitat
@Szepy,
my cylinderheadgasket is defective
CU HS
ktm-pilot
ADV1000 -->89,1KW
SzepyOffline
BeitragVerfasst am : Mo, 11. Aug 2003, 17:55    Titel: Antworten mit Zitat
@ktm-pilot
Thanx for the information.
Which one? How big is the problem?
Approximately how long did the repair take? Is it good since than?
Szepy
ApuOffline
Anmeldungsdatum: 11.08.2003
Beiträge insgesamt: 6
BeitragVerfasst am : Mo, 11. Aug 2003, 22:18    Titel: Antworten mit Zitat
@ Rainer
Hallo! Wir hatten heute mittag telefoniert.
(onkel in Oberhausen).
Ich hab wohl das gleiche pech wie Szepy und einige andere.
Entlüften hat nichts gebracht, der ausgleichsbehälter ist schon wieder randvoll.
Da muß ich wohl doch mal mein Fahrrad aus dem Keller holen, so für eins, zwei tage.
Trotzdem noch mal Danke für das kompetente gespräch.
Wegen der Vergaser und Sitzbanksache melde ich noch mal.
Ja, der Ruhrpott war einst dreckig, doch nun ist er ein Mekka für LC8-Fahrer geworden.Dank Rainer und seiner seiner Kollegen.
Ich komm auf jeden fall mal zu euch gepilgert Rolling Eyes
Ciao Andreas
Seite 2 von 4
[ Time: 0.0640s ][ Queries: 30 (0.0365s) ]
