Autor |
schlusi LC8 Junkie
Anmeldungsdatum: 29.03.2008 Beiträge insgesamt: 326 KTM LC8 SM 950, 2006 → 70.000 km KTM LC8 Adv 950 S, 2003 → 102.000 km Maico 500, EXC 200
Nach oben |
hakim Hinterradspezi Anmeldungsdatum: 12.09.2013 Beiträge insgesamt: 1578 KTM 1290 SuperAdventure, 2016 → 60.000 km KTM LC8 Adv 990, 2012 → 45.000 km
Verfasst am : Fr, 8. Feb 2019, 7:02 Titel: |
gute Idee mit der Ventilschleifpaste, danke für den Tipp!
Nach oben |
schlusi LC8 Junkie
Verfasst am : Fr, 8. Feb 2019, 23:15 Titel: |
hakim @ Fr, 8. Feb 2019, 6:02 hat folgendes geschrieben: | Hallo,
Hakim |
Hi Hakim,
leider zu spät, aber durch Zufall bin ich auf das KTM Technical Bulletin 0305 gestossen in dem auszugsweise folgendes steht:
Check Rotor mount: It is required to check if the rotor allows itself to be removed with the rotor removal tool (No. 60029009000) at 120 Nm torque.
Before attempting to do this the front cylinder must be brought to TDC and the crankshaft locked with the locking screw. Immediately following the removal of the rotor screw please clean the threads in the crankshaft to prevent contaminants from entering the oil system. Install the push screw for flywheel extractor into the crankshaft and leave in place for the possible regrinding of the rotor-crankshaft interface to prevent grinding compound from entering the oil circulation system.
The regrinding is to be done as follows: After removing the rotor apply the finest grinding compound (preferably Teroson 114.78B / finish compound ) evenly on the conical part of the crankshaft and the rotor (with removed freewheel). Placing the rotor on the crankshaft apply axial pressure and turn the rotor repeatedly forwards and reverse through an angle of approximately 45°.
CAUTION: Too much material removal can result in a condition where the rotor may not become tight against the crankshaft anymore. Having been reground, the rotor and crankshaft must be cleaned thoroughly with brake cleaner and then remounted. Another test must be conducted with 120 Nm to see if the rotor breaks loose. If not, the rotor should not be removed again. If it does break loose, the rotor and crankshaft should be ground again.
Before the rotor is remounted the threads of the screw and crankshaft are to be thoroughly cleaned to remove all traces of grease and then Loctite 243 applied. 1 X Rotor cover gasket No. 60030040100 1 X Stepless one ear clamp 22.6 mm No.00050226706
Darin steht auch, das der ursprüngliche Kupplungskorb mit dem Stabilisierungs-Metallband getauscht/ das Band entfernt werden sollte. Hat der Händler damals bei mir wohl vergessen...
_________________ ____
Gruß Christian |
Nach oben |
Verfasst am : Sa, 9. Feb 2019, 7:03 Titel: |
diese TI hatte ich nicht in Erinnerung - danke für´s Posten. Dann hattest Du ja genau die richtige Idee für die Instandsetzung.
Nach oben |
OstMarkusSponsor
Anmeldungsdatum: 24.01.2004 Beiträge insgesamt: 3385 KTM 790 Adv R → 8.000 km
Verfasst am : Sa, 9. Feb 2019, 9:43 Titel: |
Mir ist der Metallring im April 2003 noch in der Einfahrtzeit gerissen. Daraufhin wurden die Ringe von 0,8 auf 1mm verstaerkt. Jahre spaeter hab ich nen neuen Korb gekauft. War dann ganz ohne Ring.
Nach oben |
LC8 Power007 Tremalzobezwinger Anmeldungsdatum: 28.06.2018 Beiträge insgesamt: 211 KTM LC8 Adv 950 S, 2003 → 62.000 km
Verfasst am : Sa, 9. Feb 2019, 11:00 Titel: |
oh ha. Das sind ja anscheinend äußerst wichtige Informationen. Denn ich habe diesen Kupplungskorb mit Metalring. Also würdest du wohl auch sagen, den besser zu entfernen? Sollte ich ja zB abdremeln können, oder ist der sonst noch irgendwie vernietet oder so? Ich meine mich erinnern zu können, beim bearbeiten der rattermarken, da noch irgendwas gesehen zu haben.
Christian, du hast doch da gerade alles offen. Hast du den Metalring auch noch?
Gruß Mario
Nach oben |
schlusi LC8 Junkie
Verfasst am : Sa, 9. Feb 2019, 11:51 Titel: |
@ Mario, lese mal bitte deine PNs.
Ich hab alles schon wieder zusammen und bin schon wieder eine Runde gefahren.
Ich habe den Metallring draufgelassen. Es war keine Beschädigung oder Lockerung festzustellen.
Im Anhang habe ich die Technischen Informationen für die 2003er und eins für die 2005er
Edit: Ich sehe gerade auf meinem Foto, das ich die letzte Lamelle der Kupplung nicht um eins versetzt habe.
Beschreibung: |
Dateigröße: |
163.96 KB |
Angeschaut: |
268 mal |
Beschreibung: |
Download |
Dateiname: |
TI 0544 oil_jet_screw_plugs__april_15__2005_.pdf |
Dateigröße: |
336.15 KB |
Heruntergeladen: |
1475 mal |
Beschreibung: |
Download |
Dateiname: |
TI 0305 clutch_update__may_12__2003_.pdf |
Dateigröße: |
150.43 KB |
Heruntergeladen: |
304 mal |
Gruß Christian |
Nach oben |
OstMarkusSponsor
Verfasst am : Sa, 9. Feb 2019, 17:21 Titel: |
LC8 Power007 @ Sa, 9. Feb 2019, 10:00 hat folgendes geschrieben: | oh ha. Das sind ja anscheinend äußerst wichtige Informationen. Denn ich habe diesen Kupplungskorb mit Metalring. Also würdest du wohl auch sagen, den besser zu entfernen? Sollte ich ja zB abdremeln können, oder ist der sonst noch irgendwie vernietet oder so?
Gruß Mario |
nee, nix dremeln! Der hat ja seinen Sinn. Und zwar, dass der Kupplungskorb bei hohen Drehzahlen nicht 'aufgeht'. Der 1mm Ring haelt ja. Und die neueren Koerbe sind stabiler ausgefuehrt, damit sie nicht aufgehen, von daher ohne Ring. Also auf jeden Fall dranlassen!
Nach oben |
Verfasst am : So, 10. Feb 2019, 13:58 Titel: |
Oh ok, alles klar, danke Markus. Dann habe ich die Info von KTM wohl falsch interpretiert. Für mich las sich das so, dass auf jeden Fall raus machen, egal ob 0,8 oder 1mm.
Mir ist auch nichts aufgefallen an dem Ring beim rattermarken feilen.
Schönen Sonntag noch
Mario
Nach oben |
OstMarkusSponsor
Verfasst am : So, 10. Feb 2019, 16:52 Titel: |
Nach oben |
Hxlrm Fußrastenkratzer
Anmeldungsdatum: 22.07.2015 Beiträge insgesamt: 852 Honda XL 600 LM → 105.000 km
Verfasst am : Di, 12. März 2019, 23:13 Titel: |
Was muss dür die Kontrolle des vorderen Steuerkettenspanners alles ab?
Linke Tankhälfte reicht?
Nach oben |
Verfasst am : Mi, 13. März 2019, 9:18 Titel: |
Außer dem vorderen Krümmer brauchst du nichts weiter demontieren. An den kettenspanner kommt man wirklich schnell.
Mario
Nach oben |
Verfasst am : Mi, 13. März 2019, 10:28 Titel: |
Ok Danke. Dann wird der am Wochenende mal geprüft.
Nach oben |
Verfasst am : Mi, 13. März 2019, 10:58 Titel: |
Kann sein das du dir einen innensechskant zurechtmachen musst dafür, weil zwischen dem Spanner und dem Öltank der Platz knapp ist.
Nur zur Information.
Bei mir war am hinteren Spanner mehr Verschleiß als vorne. Wenn der also vorne schon Limit ist, würde ich unbedingt auch den hinteren kontrollieren.
_________________ Gruß
Mario |
Nach oben |
Verfasst am : Mi, 13. März 2019, 11:11 Titel: |
Ok.
Was brauche ich da für eine Größe für den Innensechskant?
Nach oben |
